It is currently Wed Aug 12, 2026 3:57 pm
PostPosted: Tue Apr 12, 2016 7:23 pm
Does anyone have a way to repair the screw hole for the mirage drive in a Hobie Outback, Hank Parker Edition, kayak? The plastic tube inside the hull has cracked and as a result the bolt that goes in the hole to hold the retainer will not fully tighten and will come loose when using the mirage drive.
PostPosted: Wed Apr 13, 2016 11:00 am
This sounds like the cam column. You can see a number of repair ideas in older posts in the forum. One uses a glue called ScotchWeld DP8010.
http://www.hobiecat.com/forums/search.php?keywords=DP8010&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
