It is currently Wed Aug 12, 2026 2:09 pm
PostPosted: Fri Apr 08, 2016 12:02 pm
What is kit needed to install Lowrance HDS?
Do you just need the single Lowrance install kit and the mount of your choice?
PostPosted: Wed May 18, 2016 9:51 pm
I guess what kit are you referring to?
If you have the HST-WSBL skimmer style transducer it will fit perfect in the Lowrance ready system under the Outback.
As for mounting its really all up to you. I use a one and a half inch ram ball mount on a yak attack gear track. Here is link to the Ram kit:
http://www.rammount.com/part/RAM-111U-B
PostPosted: Thu May 19, 2016 10:32 am
Here's a video that addresses Lowrance Ready compatible transducers. Referencing the 1:35 mark in the video should help address your compatibility questions:
https://youtu.be/fJd_JAIzFvI
Additionally, here's an install video for the Lowrance Ready system.
https://youtu.be/nFn3VAz01lk?list=PLaNp ... M7Vnll_hR8
If your transducer is compatible with our Lowrance ready system, the things you will need are the Lowrance Ready install kit (72020070), a RAM base and appropriate RAM fishfinder mount.
Howie Strech
