It is currently Wed Aug 12, 2026 12:13 pm
 Post subject: T-9 bioshield
PostPosted: Wed Apr 13, 2016 2:27 pm
Has anyone tried this stuff for their mirage drive? Says it's waterproof and will not harm plastics or vinyl. Also says it is good for protection against salt water. I just got a new outback and was looking for a good lubricant for the mirage drive. Thanks for any feedback
 Post subject: Re: T-9 bioshield
PostPosted: Wed Apr 13, 2016 4:09 pm
It's all I've ever used on my Mirage Drives. So far, so good, going back about 8 or 9 years now.
PostPosted: Wed Apr 13, 2016 5:30 pm
Thanks Tom
PostPosted: Thu Apr 14, 2016 8:53 am
HOBIE MULTI-LUBE
A planet-safe lubricant recommended for lubricating MirageDrives and many other uses. Environmentally friendly for in-the-water applications. Hobie Multi-Lube offers excellent lubrication, is an anti corrosive coating, great for cleaning and many other uses... use on nearly anything that squeaks, rusts, corrodes or binds up; MirageDrives, rudder drums, cams, fishing reels and more. The 1 oz size is perfect for getting the lubricant into tight spaces by using the needle applicator. The 4 oz size has a spray applicator for coating chains and larger surfaces, shafts and bulky parts. Every Hobie owner should have Hobie Multi-Lube.
Be nice to our planet, keep MirageDrives and other components running smoothly and lasting longer without polluting our waterways. Use it for all shop, home and sport lubrication needs.
5120 HOBIE MULTI LUBE 1 OZ
5121 HOBIE MULTI LUBE 4 OZ
