It is currently Wed Aug 12, 2026 2:57 pm
PostPosted: Mon Jun 06, 2016 6:36 pm
I have a new Garmin and want to hook it up to a Hobie Lowrance Install kit battery. The battery plug does not mate with the Garmin fishfinder.... any way to modify this or must I get a Lowrance fishfinder ?
PostPosted: Mon Jun 06, 2016 7:35 pm
For a battery you can use whatever kind of plug you want, I'm using the plugs from the Genius chargers. The Lowrance cable has bare wires and you add the plug that comes with the Hobie kit. The Garmin must have come with a battery cable? One end should go to the ff and the other end should go to the battery.
Brian
On the bank of the Bow River
PostPosted: Mon Jun 06, 2016 8:08 pm
Brian
Thanks, yes there is a battery cable with the Garmin..it has 1 red, 2 black, and one brown wire.... ?
PostPosted: Mon Jun 06, 2016 9:37 pm
On the Lowrance there were two wires that weren't used I cut them off and sealed the ends with a bit of heat shrink. You probably want the red and one of the blacks but I would check the installation manual to be sure.
Brian
PostPosted: Tue Jun 07, 2016 2:58 pm
I sent an email to Garmin Customer Service asking how to hook it up.....I'll advise on what they say..
PostPosted: Wed Jun 08, 2016 6:14 am
My buddy just got a Garmin, I just sent him a message too to check.
Brian
PostPosted: Wed Jun 08, 2016 9:23 am
He confirmed that it's black and red, there should be a brown and blue leftover for other accessories.
Sent from my iPad using Tapatalk
PostPosted: Wed Jun 08, 2016 4:08 pm
Indeed....not 2 black, but 1 black and one blue.....makes it simple....I'll tie off the brown and blue just as you did.
Thanks Brian..
