It is currently Wed Aug 12, 2026 2:59 pm
PostPosted: Tue Aug 16, 2016 8:59 am
Ok first of all I'm not proud of my install, I know it looks like crap, but should be %100 functional. I ordered from mariner sails a Berleypro total transducer for my Lowrance 7ti total scan. Then a plug with three outlets for different cabels. I used plugs from my Hobie kit but they kept slipping out, I still used them but they didn't fit flush or at least the plug with two cords. Thinking back I probably should have split them cause the mount has three plugs. I just had my prior install in mind where the mount only had one plug. I used a bunch of marine sealant to make it as water proof as possible. I think I succeeded- lol. I plan on going tomorrow for crappie so if I don't forget I will try and take pics of my screen. It does stick out a bit (the transducer cover) and was a PITA to install the three bolts. I had the plate to the transducer backwards first time, I recommend looking at a install to make sure you get it right. I think I found it here. I just googled to find an install. I like not seeing the arm hanging off the side. Hopefully it works out for me. If not I will enjoy beating that thing with a hammer lol. I had to drill a hole for the cable plug, I think it was a 1" bit. I will include pics of my install
All Fisherman are liars except you and me, but sometimes I wonder about you.
