It is currently Wed Aug 12, 2026 1:16 pm
PostPosted: Sun Sep 25, 2016 5:00 pm
Have had my Rev 11 about a year now and finally out in ocean with it fishing for stripers. I mostly stay in/near harbors and have not strayed further out as don't think my Hobie big enough for big water. I want to add some gear like electronics (fish finder, battery, etc.) fly rod holder (https://www.youtube.com/watch?v=-OonwVQXVp8), through the hull transducer, etc. Need everything to be light and quick connect/disconnect as I can just about get naked Hobie into saddles on top of my car by myself at 65 y.o. Cannot spend a ton of money and not bad at DIY stuff especially when I can see a YouTube video. Just looking for some thoughts and ideas here. Thanks from a not so old broad yet.
PostPosted: Mon Sep 26, 2016 3:25 pm
I take my Revo 11 out front all the time. Is the perfect light all around kayak. It's made to handle rougher waters.
Fish finder can be tricky on the Revo 11, due to it being the only non Lowrance Ready mirage kayak. As far as I see it, you have two choices on transducer placement. One, thru the hull, just use some duct seal to form your transducer to the kayak hull. Make a cup and add a little water for even better signal. Or two, a bit more work, run your transducer thru one of your rear scupper holes. I used PVC with a threaded cap, drilled out, epoxy any parts together including the ducer to the pvc. Use the Hobie thru hull wiring kit for either method.
Next you need to choose a battery. I'm inclined to use a Lipo battery, 1/3 the weight and about the same cost. Should be lots of videos online or threads here in the forum.
Mark
Tandem Island- 2013
2 - Sports - 2014
PostPosted: Mon Sep 26, 2016 5:14 pm
Here's my recommendations for a starting point on accessorizing your Revo for maximizing fishing functionality:
As for fish finder stuff:
Fish Finder - pick one of your choice
RAM mount 72023053
RAM base 72023044
Fish finder install kit - part no. 72020101 (comes with 12v battery, waterproof wiring and connectors, wire harness and connectors, 12v charger, hobie battery holder, 3-way thru-hull fittings, foam transducer pads, zip ties and marine goop)
Other accessory recommendations:
H-Crate 72020088
Rod Holder Extensions, sold as 1 ea. 72020014
One additional rod holder w/ base of your choice to fit in front of your seat, opposite of your fish finder
Howie Strech
PostPosted: Mon Sep 26, 2016 5:38 pm
Thanks Mark, I had pretty much decided to go the duct seal route and go with a LIPO battery but nice to see you verify that route. I often do not truck my Hobie Wheels back to car, especially when that is a long distance, so I stick them upside down through the rear scupper holes. I have a scotty fly rod holder so today built a removeable Hobie mount for it similar to the link in my original post here using PVC parts and u-bolts and it fits very snug into Hobie rod holder. Just need to decide on a reasonably priced fish finder now with GPS cookie crumbs, backlit, pin drop capability, easy connect/disconnect system, etc. Then I might rail track mount it. A couple of people recommended the "Dragonfly" but have not checked that out yet.
PostPosted: Mon Sep 26, 2016 8:46 pm
I suggest that you mount a pair of gear tracks on the gunwales of your 11’ Revolution in front of the pockets. This will provide you with great flexibility about how you set up your kayak, both from day to day and during a single day. It will let you change the way your kayak is set up for different kinds of fishing. It will allow you to change the way your kayak is set up as you learn from experience and from other kayakers. It will let you change from one brand of accessories to another. The disadvantage of installing fixed mounts on your kayak is that in six months you may wish you had installed the fixed mount someplace else, or you may wish you had installed a different brand of mount.
Here is where I installed gear tracks on my 13’ Revolution. I find that I locate most of my gear on the rear half of these tracks, where it is easier to reach, so if you want to save money, you could install shorter tracks.
Here is the way I set up my kayak for trolling and downrigger trolling. For an explanation of why I set it up that way, and how I mounted the downrigger, see http://www.northwestkayakanglers.com/in ... #msg138905 . The rod is located about two inches behind my left toe when my left pedal is all of the way back. This puts it completely out of the way of my pedal stroke, but close enough to my seat so I can grab it quickly when I get a strike.
But with gear tracks, you can do just about anything. For example, here is how I can set up my kayak to downrigger troll off the right side of my kayak while running a planer board off the left side of my kayak, with a rear view mirror to monitor the planer board. See http://www.northwestkayakanglers.com/in ... ic=17409.0 for details. This is perhaps a little over the top, but the point is, if you base your kayak outfitting on gear tracks, the tracks give you the flexibility to do just about anything.
Before you purchase any tracks, reach inside your kayak and feel the inside of the gunwale in the area where you are thinking of installing the tracks. Check the shape of the area, and look for obstructions, cables, and other things which may interfere with installing the track. The inside of the gunwale of a 13’ Revolution in the area next to the cockpit is pretty narrow and arched, and I suspect that an 11’ Revolution is similar. If you want to install the gear track using bolts and nuts, it’s difficult to drill holes which are lined up accurately in the arched area inside the gunwales. The holes are likely to emerge on an angled surface inside the gunwale. You probably aren’t going to be able to use a backer bar, and if you use fender washers, you’ll probably need to bend them to fit the arched inside of the gunwale. I used YakAttack 1.75 gear tracks. They are hideously expensive, but a major advantage of them if you have a Revolution is that they can be mounted with screws from the outside of the kayak easily and quickly. And because they are wide, they do an excellent job of resisting the leverage from rod holders. I have heard a rumor that Lucid Fishing is about to start offering very similar gear tracks which are less expensive, but they aren’t shown in Lucid’s webpage yet.
PostPosted: Mon Oct 03, 2016 5:55 am
I'm pretty new to kyaking myself. I have a Revo 13, and added a gear track to the left side. I mount a rod holder and a FF to that side. I'm thinking about adding a track on the right, but I feel that might make it more difficult to swing my legs over if there is gear attached. Behind the seat I've added a basic milk crate, with two home made PVC rod holders for the extra rods. It's secured with the bungee. That leaves me enough space to store a Plano tackle box btwn the crate and seat.
PostPosted: Mon Oct 03, 2016 12:58 pm
That is quite the rig Pete! Nice job! It is more than I would want on my 11' Revo both for safety reasons (re-boarding if I take a dump - esp. in the ocean) and for maneuverability while in my yak. I do plan to install a gear track though so thanks for the heads up on that and a better place to buy a good one more reasonably priced.
PostPosted: Tue Oct 04, 2016 4:18 pm
I'm not a big fan of the rail trax. Better to mount directly to the kayak hull with quick disconnects. Use railblaza to connect your fish finder to the small cup holder on your left hand side. Lots of mounts for a rod holder. Could go with Railblaza there too.
Obviously use the same side of the hull for both holders, so as to keep the other side clear for fish landing and water entry.
Mark
Tandem Island- 2013
2 - Sports - 2014
