It is currently Wed Aug 12, 2026 2:59 pm
PostPosted: Mon Apr 24, 2017 8:11 pm
I'm installing the Yak Power wiring system on my 2017 Hobie Pro Angler 14 to control the Lowrance HDS Carbon 9 with 3D StructureScan and Point-1. I'm using the Bioenno Power 30Ah LiFePO4 battery to power everything.
https://youtu.be/RF2JXYYa0n8
PostPosted: Sat Aug 26, 2017 12:52 pm
Hey I have watched all of your rigging videos. Out of all the switch panels and Power Systems you have used which one do you recommend? I am wanting to run a power pole, 7" fish finder, lights, and a usb port would be nice.
I do not really want to cut a large hole in my kayak. I do not mind cutting the hole for something the size of the yak power system.
Thanks in advanced!
Tracy
PostPosted: Fri Sep 08, 2017 8:30 am
Thanks in advanced!
Tracy
Tracy
First, thanks for watching the videos. The Yak Power system does make wiring much easier and cleaner. I won't install a wiring system any where other than the hatch bucket, so the Yak Power makes it easy to install and remove the bucket without modifying it like I had to with the marine switch panel. Having the USB port in the hatch bucket is the best location that way my cellphone or tablet is safe while charging.
