It is currently Wed Aug 12, 2026 10:03 am
 Post subject: Lowrance Hook 4 Issues
PostPosted: Wed Aug 02, 2017 9:30 am
Hello, I'm new to the forum and hopefully I am posting this topic in the correct location.
I have a 2015 Outback with a Lowrance Hook 4 Fish Finder. It works well in shallow water (< 5' deep) and then flashes the depth and shows a lot of interference at anything deeper. The unit has worked well in the past and I have only noticed this the last two trips out. Any thoughts? I am using the in-hull set up and the transducer has about 1/4" or so of clearance from the base plate.
Thanks.
PostPosted: Wed Aug 02, 2017 5:57 pm
I had that problem last week. I found that when I dragged my yak into the water tail first the transponder housing filled with sand. Once cleared, it was fine. I'd check if the housing is clear.
PostPosted: Thu Aug 03, 2017 8:50 am
Thanks for your response JohnsYak, I should've mentioned in my original post that the housing was clear and clean. That was my first thought too!
PostPosted: Thu Aug 03, 2017 10:48 am
I would contact customer support at Navico and have them help troubleshoot: 800-628-4487
Howie Strech
PostPosted: Wed Aug 09, 2017 5:04 am
Sorry for the slow response, I've been on vacation with no internet access.
Thanks for the phone number HStretch, that's a great idea and I'll check in with them.
