It is currently Thu Aug 13, 2026 3:26 am
PostPosted: Fri Sep 01, 2017 12:36 pm
Did this occur when I launched or came in from La Jolla?
I was having issues with my Hook 5 not showing the bottom definition past 130 feet or so.
Fresh: http://www.youtube.com/playlist?list=PLE02E23641B7FE360
Salt: https://www.youtube.com/playlist?list=PLeb5zOGDfoKlEPsMK5GBUOge_Qz5u2koH
PostPosted: Fri Sep 01, 2017 1:08 pm
Somebody had a brilliant idea in response to this...
here we go: https://www.hobie.com/forums/viewtopic.php?f=26&t=51295
It doesn't really affect my transducer (Hook4) on the way out to sea and when I come home I always hose off the kayak including the transducer pocket. I think it would only be a problem if you allowed sand/debris to build up in there.
PostPosted: Fri Sep 01, 2017 1:25 pm
Thank you!
PostPosted: Fri Sep 01, 2017 8:17 pm
I'm guess it can happen if you slide your kayak backwards on the sand. Even if only slightly while unpacking or manoeuvring onto trolley. I find the seat drain venturi drain gets blocked as well.
PostPosted: Sat Sep 02, 2017 6:14 pm
I find that drain plug utterly useless :lol:
I'm probably going to modify it to pass a wire for an underwater LED instead.
