It is currently Wed Aug 12, 2026 2:42 am
PostPosted: Fri Nov 23, 2018 10:54 am
Do standard 7.5" aluminum pliers fit inside the deep gear bucket at an angle?
PostPosted: Sat Nov 24, 2018 5:59 am
They do, but. Always a but isn't there. Anything hard like a pair of pliers, or a plastic box, or a water bottle that leans against the side of the large bucket very quickly makes a crack in the side. These buckets are soft and while not fragile, they are not sturdy. In 10 years time I've had 4 or 5 and the one I have now is duct taped and awaiting replacement. I wish Hobie would make one from the same material as the rectangular hatch bucket.
You would be best to either try and find a pair of pliers that will fit flat in the bucket or another way to store your pliers. The side net, if you have one, is a perfect place to store them. My pliers usually end up in the floor after the first fish anyway. Use your cord to keep them from sliding under the seat.
Duncan
PostPosted: Sat Nov 24, 2018 10:49 am
Yea I know about the side pockets was just worried about the screws interfering with the rudder cable on the Compass.
PostPosted: Sat Nov 24, 2018 8:32 pm
Here is another idea.....
Since I always wear my PFD, I carry my 6 3/4" long pliers on the front of my NRS PFD as shown. The Shimano pliers pocket will handle longer pliers.
The retractable SS leash works great and I never need to go looking for the pliers.
I also carry the smaller split ring + cutter pliers for spectra type line, in the RH vest pocket (left side of the photo). It's leashed too.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Nov 25, 2018 7:03 pm
That's crazy that a water bottle will end up cracking a $25 bucket.
Do regular sized Fish Grips (not the Jr) fit inside the Hobie Mesh Pocket enough that I wouldn't be worried about them flying out while full speed pedaling?
PostPosted: Mon Nov 26, 2018 6:40 pm
I just clamp on my seat. I have rubber map pockets that have some give to them and never had anything fall out. If anything else I use a small tether for things I worry about losing.
All Fisherman are liars except you and me, but sometimes I wonder about you.
