It is currently Wed Aug 12, 2026 7:58 am
PostPosted: Tue Jun 15, 2021 12:07 pm
I took off work on Friday the 11th to fish the Columbia out of Stevenson, WA. I did so because the weather report indicate little to no wind all day long. To say that I was upset when I got the ramp and saw white caps and rollers would be quite the understatement. I almost did not even launch.
I decided that since I had driven an hour to get there I should at least get the kayak wet. The wind had me in a foul mood as I launched. When I reached for a rod I noticed that I had forgotten to leash my rods (I keep the rods I am not fishing with leashed to the kayak in case I tip). As I was reaching around to hook the rod leashes up I caught the sleeve of my raincoat on a treble hook. I grabbed my pliers and tried to back out the hook while on my knees in the kayak which was rocking around like crazy due to the waves.
I created about a foot long tear in the sleeve of my rain jacket when I pulled on the hook just as a bigger roller hit the kayak. Just perfect.
By this point I am out and out seething about the weather and my sleeve. Once again, I almost pack it up and even started to pedal back to the ramp but I decided to stay at least for a little bit.
I started fishing and in a bit caught a small bass. I kept fishing a caught a few more dinks (which is unusual for the Columbia, usually good-sized fish abound). I am just getting angrier and angrier by the minute. To add to my good mood I snap off my favorite spinnerbait on a cast. I must have had a bad nick in the line. Grrrr.
I finally catch a decent sized bass (2 1/2lbs) and that cheered me up some but it was a stray fish. In the wind and the rain (which is nicely soaking through my torn sleeve) I could not put together a working pattern. Every fish I caught seemed random and unrelated in its behavior and location to any previous fish.
Further down after another lull I hook a second nice fish and lose it right at the kayak. "You have got to be kidding me" I said to myself. Crank and wind, crank and wind, feel the chill as my sleeve and arm just get wetter and wetter.
I fished one of my favorite spots and did not get a sniff, but it was just so hard to fish in the wind and the waves. I went and fished some other known good spots and caught a couple of more fish, but nothing notable. I could barely concentrate on fishing as I just kept thinking that I burned a day off from work for this and the anger would boil inside me.
Late in the morning (I am still not sure why I stayed) the wind died down and so I went back to my favorite spot. With the calmer wind I could actually fish it effectively. It was as if a switch was flipped. The bite turned on hard. The fish were deeper than I expected with the overcast conditions (10-15') and would not consistently hit a moving bait but they could not lay off the Ned rig.
I ended up with 33 smallmouth on the day, mostly on the Ned rig. I had a 3lb, 3lb 2oz and 3lb 6oz fish and lots of fish over 2 lbs. I still occasionally caught a dink but they became the exception rather than the rule. A morning that was close to one of my worst ever turned into and afternoon that was good as they get!
The fish never got super active and I would periodically waste time throwing an active bait. Occasionally I would catch a small fish doing that but then I would go back to the Ned rig and start catching quality fish again.
That had to be the biggest 180 of a day I have ever had. By the end the water was like glass and the bass kept biting all afternoon and were still biting well when I left. I am so glad that I just sucked it up and hung in there. I almost rage quit so many times during the day. Some days you just have to be relentless.
3lbs
3lbs 2oz
3lbs 6oz
Some video from the day:
