It is currently Thu Aug 20, 2026 5:31 pm
PostPosted: Thu Apr 08, 2010 5:21 am
For those that added a jib to their inflatable sails..
How did you attach the new stays to the top of the mast?
Drill thru the mast? new fitting on top of the mast?
(i can't tell from the pics that pple have posted how this was done)
PostPosted: Thu Apr 08, 2010 7:37 am
At the top of the inflatable sail there's a band of heavy material that prevents the sail from sliding down the mast.....loop your side stays to that.
Tie off a second set of stays to the original stay location. This will give support to the upper 2/3rd's section of mast.
Both stays terminate to the same snap shackle at the hull. When you're setting up the stays for the first time they don't need to be tight, just snug, the hull is going to flex a lot while sailing. Just make sure your mast is perpendicular side to side, and you may want to rake your mast forward a couple of inches to prevent weather helm.
This is the way I set up my boat and it works great. I posted how to instructions about a year ago. Do a search on i14t performance question.
Good luck.
