It is currently Thu Aug 20, 2026 5:01 pm
 Post subject: Sail Furler kit
PostPosted: Sat Nov 21, 2015 5:15 am
The furler instructions are not much help with this issue. With my Oasis, if I secure the furler assembly at more or less level with the fairlead as indicated in the instructions, the pedal fouls the furler lines. Solution is to secure the furler assembly further up the mast but this means the furler lines will meet the fairlead at about a 30 degree angle. Is this how it is meant to be installed?
All advice is appreciated.
 Post subject: Re: Sail Furler kit
PostPosted: Mon Nov 23, 2015 7:35 pm
can the fairlead be moved further forward to move the lines clear of the pedals? I would think that this would be better than having the furler that much higher than the lines.
2015 Outback- dune with sail kit
2015 TI- dune- sold
2015 AI2- Hibiscus- should probably sell...
2018 AI2- Dune
PostPosted: Wed Dec 02, 2015 3:13 am
I could move it forward however the install diagram shows it at an angle. You'd think Hobie would have better instructions.
PostPosted: Wed Dec 02, 2015 9:32 am
The instructions are generic as models and pedal positions vary.
Two important parts... Height of the furler and position of the double fairlead.
Item 2:
Locate the best height for the furler on the mast. This will vary depending on your kayak model.
Item 3:
Fairlead Mount to the rail of the kayak. Mark 5” behind mast base to the center point of the Fairlead.
I'm surprised if this causes conflict with the pedals... long legs? Instructions should include a note about checking for pedal conflict.
PostPosted: Sat Dec 05, 2015 4:42 pm
http://youtu.be/H_stDzQJ1ow
