It is currently Thu Aug 20, 2026 5:24 pm
 Post subject: Nut found in hull
PostPosted: Sat Sep 02, 2017 4:01 am
Hello. I just found a nut in the hull of my 2014 Adventure Island.
Any ideas from where this nut might fall off?
Thanks in advance for your replies. Image
Sent from my SM-N910C using Tapatalk
 Post subject: Re: Nut found in hull
PostPosted: Sat Sep 02, 2017 3:06 pm
I think the most likely source is one of the brackets that attach the AI mast receiver bottlescrew braces.
I remember (having taken my very early AI apart to replace a hull) that there are two braces, one either side that go from the bottom of the mast receiver to the aka bar in some way where they locate onto a threaded rod with a nut to hold them in situ, but not having my boat available to look at I am having difficulty remembering the exact setup.
Either way, since most of the deck fittings do not penetrate the hull but attach via moulded-in inserts, what you need to identify is a fitting where there would be a screw-thread protruding into the hull or one that is part of a fitting already inside the hull. I suspect that the braces aforementioned are one of your first places to look.
Hope this helps & please report back!
PostPosted: Sat Sep 02, 2017 4:41 pm
There is a possibility it is an extra -- dropped in the hull during assembly and wasn't retrived. This has happened to me. 8)
PostPosted: Tue Sep 05, 2017 12:15 am
Hello guys. Thank you very much for your replies. I checked everything inside the hull and no nut is missing. So maybe there is a left over or something. The funny part is that I found the nut after 3 years that I own the AI. Lol.
PostPosted: Tue Sep 05, 2017 9:10 pm
Mighta sneaked in through those rudder cable tubes... :wink:
PostPosted: Wed Sep 06, 2017 12:08 am
lolololololololol
