It is currently Fri Jun 19, 2026 5:06 pm
 Post subject: Rear cross bar bungees
PostPosted: Thu Jun 30, 2011 12:42 pm
Could someone try to explain the rigging of the rear cross bar.
PostPosted: Thu Jun 30, 2011 4:30 pm
Bolting to the boat?
Lacing of the trampoline to the crossbar?
Main blocks onto the car?
Not sure what you are looking for.
PostPosted: Fri Jul 01, 2011 11:51 am
Trap rigging. Actually the whole rigging of the rear trap other than the wire to the mast.
PostPosted: Fri Jul 01, 2011 12:09 pm
The rear (skipper) trap bungee doesn't go to the rear crossbar, it goes under the tramp.
There is a small block that gets tied to each shroud adjuster. You tie off the bungee to one side of the trap system, pass the bungee throuh the block on the shroud adjuster, then through the grommet in the tramp, under the tramp and up through the grommet on the opposite side of the boat, through the pulley tied off on the opposite shroud adjuster and tied off on the trap line on the opposite side.
You should probably just download the manual for the boat.
http://2010.archive.hobiecat.com/support/pdfs/H20Manual.pdf
