It is currently Sun Sep 13, 2026 5:48 am
 Post subject: Dolphin post corrosion
PostPosted: Wed Dec 24, 2014 3:13 pm
Hmmmm, can't seem to tighten this up due to corrosion as shown below. I think my only option is cutting it out and replacing.
Any thoughts....anyone.....anyone.....
H18 '85
H18 '89 "Knotty Passion"
H20 '96 "20/20 Vision"
Fleet 259 Central Coast California
PostPosted: Wed Jan 28, 2015 1:54 pm
Hello Scott:
In 2010, I replaced my dolphin striker post (40140001) because of the same thing and had to hacksaw out the old one.
Was not too bad to do.
- Dwight
Dwight Manning
Hobie 20 #916 San Jose CA 2000 Alter Cup
Hobie 20 #16 San Jose CA (Jordan) 2000 Alter Cup
Hobie 18 #916 Santa Cruz CA 1989 Worlds Boat
Hobie 16 #16 San Jose CA (Jordan) 2005 Custom Main
Hobie 16 #54466 Calling Lake Alta Tequila sunrise
PostPosted: Wed Jan 28, 2015 2:35 pm
It looks like you could install additional washers under the nuts. Use a 300-series stainless to minimize galvanic corrosion.
1985 Hobie 14T
2014 Hobie T2
PostPosted: Wed Jan 28, 2015 3:15 pm
Unless I'm missing something, I think you should be able to just loosen the nuts at the ends of the striker rod (remove the outoard crossbar end caps) and then pop the rod off the post. Then remove the ball and the top nut and drop the striker post down out of the front crossbar. Then use a dremel tool with a cut off wheel to cut the compression sleeve lengthwise and split it off the post. Then clean up the post, replace the compression sleeve (use tefgel) and re-install everything.
