It is currently Mon Aug 03, 2026 1:16 am
PostPosted: Fri Oct 03, 2008 6:17 am
So Dan,
What are the mods that make the Tiger more competitive?
[quote]I wonder if my 2003 Tiger will be the oldest one at the NAF18 North Amercians in Pensacola? It is not a â€
Mike Hensel
'86 Hobie 18, '93 Hobie 14, '80 Hobie 14(restso in progress)
Wind in your sails, water in your shoes, great day!
PostPosted: Fri Oct 03, 2008 7:17 am
The new jib without the roller furling system and the post 2006 spi are definitely worthwhile. STX or Ullman main a must. Other things are just minor modifications. What pays most is time on the water.
PostPosted: Fri Oct 03, 2008 3:55 pm
I have kept up with the rule change options such as the STX main and the new cut spinnaker. I also have removed the furler.
I was currious, because it sounds like Dan had some inovative ideas that are beyond the norm.
Thanks for the input.
Mike Hensel
PostPosted: Sat Oct 04, 2008 3:31 am
I have seen quite some modification on these last Worlds, for example the Heemskerk Tiger has a mecanism that permits raising the left daggerboard from the right side by the means of a band inserted into the daggerboard which can be pulled from the rhs. This definitely makes the spi preparation faster and might save you a second or two. Also a lot of rubber bands under the tramp, clean layout etc. But I think this does not make the boat any faster, it is for faster manoeuvres. As an other example there was Mitch's boat, stock Tiger, the only modification I could see was the possibility to control mast rotation from the wire (which will be the next thing I'll add to my Tiger).
PostPosted: Sat Oct 04, 2008 6:35 am
Mast rotation from the wire is one thing on my list for this winter, moving the rotator to the mast base. On my FX One I had that option and found it very helpfull.
As far as the the idea regarding the dagger board that sounds like an excelent one. Would it be Hobie class or F18 legal to modify the board?
Mike Hensel
PostPosted: Wed Oct 08, 2008 10:12 am
Mike:
First of all I would like to point out that I do NOT think the Tiger is a slow boat. I am still racing one and feel that I am competitive with the rest of the fleet.
Having said these are things that I have done but do not promote doing:
Shortening the bridle wires and lenthening the forestay. I have pulled the jib down to where the newer Tigers jib will be. I did this know that I am putting more sideways pressure on the hulls but feel that the boat is built well enough to take it. In doing this mod I am using a bridle forestay connector from Nacra.
I have the newer rudders on the boat which I really like. Some think it is not a good idea. I feel that the boat sails more agile. It used to be harder to pull the bows down without stalling the rudders. By the way these rudders put the leading edge further forward of the pivot point so they have a power steering feel to them.
Other things that cannot be attributed to actual boatspeed but I would argue that convenience equates to speed:
Endpole spinnaker - I am the only one that likes it so do not go out and change your boat immediately. I feel that we can hold the spinnaker up longer at the leeward mark with this set up. Others think it is too much windage.
Mast Rotation adjusters on the hull for ease.
16 to 1 downhaul
Spinnaker halyard cleat up on the mast so Eileen can stand while hoisting.
Footstraps at the very back of the boat so crew can feel safe trapping downwind.
Spinnaker is neither old style or new style but somewhere in between. I think the new style is designed for speed. Problem is that it is hard to hold and makes the crew tired quickly, thus not always trimmed. The old style was easy to hold but not as fast. I have a Glaser sail which is easier to hold than the new cut and I feel just as fast. If my spinnaker works optimally all the time and yours, due to fatigue, works only 80% of the time, I am faster.
Double ratcheting blocks on the spinnaker sheet for all of the same reasons as the last paragraph. One of them I can turn off in light winds.
Center strap on the trampoline so I can sit comfortably downwind. Because the crew is all the way back while trapped out downwind I have to move in a bit so the spin sheet can clear my body. I am all the way back and do not think I am hindered much in this position. I can more easily see under the main at traffic, VERY IMPORTANT! By the way I also send Eileen out on the wire early so she can hold the spin sheet easily.
I make my own harnesses. I have not found one that is more comfortable that the ones I make. I have done this for close to 20 years. Another advantage to this is if I need to modify them I am not afraid to since I did not spend $300 each on them.
Oh I almost forgot. Keep the deck layout clean and the boat in good shape. Change rigging. Do not keep the same stuff more than two years.
Last but not least. SAIL A LOT! You do not have to be racing to learn how to go fast. Just having the boat under you as much as you can will make you faster.
Later,
Dan
PostPosted: Wed Oct 08, 2008 10:39 am
One of the local Tiger sailors uses Spinlocks for the downhaul cleats. Works really well. I didn't get a chance to try it anywhere but the beach but it is one of the things on my list for this winter with the FXone, (along with the 16:1 downhaul).
