It is currently Mon Aug 03, 2026 12:43 am
PostPosted: Mon Jul 06, 2009 5:21 pm
Any suggestions on how to reduce the friction from the end pole snuffer OEM version?
I am using the German sail friction coating which is excellent BTW.
Cheers
Alan
PostPosted: Thu Jul 09, 2009 6:47 pm
See if you can separate the dousing points from each other with a knot. Put it just below the top patch so the two patches will not come in together. If you can get them even as little as 1 foot from each other you will have an easier time with it.
Later,
Dan
