It is currently Mon Aug 03, 2026 4:35 am
 Post subject: self tacking sistem
PostPosted: Mon Apr 23, 2007 1:42 am
Hello, I'm new in this forum, I' from sunny Sicily so excuse my imperfect english. I have been reading many articles here so I learnt many tricks in handling the Tiger i bought just one year ago (it's my engineering degree gift). Now I' setting my boat with a self tacking sistem and I would like to know if there is a way to set a close circuit with only one sheet to sheet the jib and control the slot between the two sails (like the main system).
Thank for sharing your experience and your time.
COME SAILING IN TAORMINA!
PostPosted: Tue Apr 24, 2007 8:22 am
I never change the adjustment of the slot of my Tiger (using the traveller). I tied it to were I thought the optimal position was for the traveller and sail with it there all the time. The sheet will adjust the slot of the jib to mast as well as mast rotation.
Later,
Dan
PostPosted: Thu Apr 26, 2007 1:04 am
Thank for your reply, Mr. Delave, how far from the centre of the rail do you fix the car?
Thank you, Mattvin
PostPosted: Thu Apr 26, 2007 8:58 am
I do not know the exact distance. What I do know is that it straddles the post that secures the track to the front crossbar. Not the outside one but the one just in. There are four, so the middle ones.
Dan
PostPosted: Fri Apr 27, 2007 10:31 am
Mattvin,
You don't have to call Dave "Mr. DeLave".
He is just fine with "Sir" or "Lord Dan". :wink:
2003 Tiger - Don Atchley
 Post subject: softening top cover
PostPosted: Sat Apr 28, 2007 1:59 am
Though being a Captain, You shouldn't joke an Admiral, because he could hurt and close the forum! :wink:
Does anybody know how to repair the top cover between two beams that is no longer hard?
It flects under the weight of a man who sits on and I think to put a layer of fiberglass on his internal side to harden the whole part.
Is it a good idea?
Hi, Mattvin
PostPosted: Tue May 01, 2007 6:15 pm
Wow Lord Dan! Never thought of it. Sounds kind of cool though.
Is the top cover are you talking about the deck inspection plate? If you are talking about that do not try any repairs it costs about $12 to replace. I just bought two, one was stolen (or somehow needed) from my boat. I decided to have one extra...in case. You will spend more time than it is worth to try to fix one.
Later,
Dan
PostPosted: Wed May 02, 2007 12:41 am
Sorry (for me) but the flecting top cover I'm talking about is the long one between beams. It's fixed to the hull, not screwed like inspection ports, and it 's shown in the Illustrated part guide at page 2 with 18090075 code number (decks).
Bye, Mattvin
PostPosted: Wed May 02, 2007 9:23 am
I looked at the illustrated parts diagram you referenced. I'm not sure what you are trying to describe. There should only be an inspection cover just behind each crossbar.
In the picture they show the slot for the daggerboard, but there should not be any cover on that!
PostPosted: Wed May 02, 2007 9:55 am
you talking about the red area?
That is just FRP in a mold. I would think that if you could pry it off you could just add some reenforcement to the back to stiffen it. If you would like to make sure you have a competitive boat, weight-wise, you may need to take some precaution to how much material you want to add.
PostPosted: Wed May 02, 2007 10:11 am
Yes, that's it!
Now the one million dollar question is: how can I pry it off? :roll:
PostPosted: Wed May 02, 2007 2:40 pm
I had one of the front ones lifting up from the hull and had to glue it back down. I think that I could have put a plastic wedge in the gap and tapped my way around the perimeter to get the whole thing off. It may take some to start it and it may be a bit messy but I think it will come with a wedge the rest of the way.
Later,
Dan
PostPosted: Fri May 04, 2007 6:58 am
I have removed that piece on a Fox. It is not as easy as you would think and will most likely damage it. If you are going to do it make sure there is a replacement available in Europe. The white material that is used around it to seal is not easy to source either. I ended up using a white 3M product to seal the cap. IMO its not worth removing it to reinforce.
PostPosted: Fri May 04, 2007 8:38 am
I will be in Italy at the beginning of June and would love to help you fix the decks. Of course we'd have to go for a sail soon after. I am very experienced with this type of work...
Trey Brown
www.velocitysailing.com
2006 N20 1017
1998 H16 102698
www.sunjammers.com ftw!
PostPosted: Sat May 05, 2007 2:49 am
I just can't ask for more, I will be honoured to be helped by you to tune my cat and have some trips in Giardini Naxos bay (Sicily), the place I live in.
That will be the period when I set up the boat that waits disassembled in a garage and will begin the second sailing season with her (I'm just a deck hand).
Tell me more: where are you going to go in Italy and how long are you going to stay here?
See you soon, Mattvin
