It is currently Mon Aug 03, 2026 1:41 am
PostPosted: Sun Nov 08, 2020 12:37 pm
Hello everyone,
I'm trying to get back into cat sailing and I can get my hand on a Hobie f18 tiger from 1998, complete with the spinnaker and the road trailer for about €1600/ $1900.
The only issue reported is that the boat has 2 leaks, 1 in each of the daggerboard case( I have some pictures here https://photos.app.goo.gl/5jyVSLgRMe3EZgyz6 ).
The current owner tells me that the leak was caused by them running in a sandbank which caused a previous repair to fail.
It currently is taking too much water to be sailable.
I haven't seen the boat in person yet but is it even worth moving forward, knowing about the leaks? How much of a pain would it be to fix a leak in what sounds like a painful place to work on.
Is it worth it after taking into account the price ?
Thanks in advance for your advice !
PostPosted: Mon Nov 09, 2020 6:29 pm
I’m sure it can be fixed, but I guess it really depends on whether or not you’re looking for a fixed-uper or looking for a more turn-key boat. The repair would probably involve cutting an access port in the deck to gain access to the inside of the hull in order to re-glass the trunk to the hull and then also grinding out the broken glass on the outside and re-glassing the outside. But unless you’re familiar with fiberglass repairs, you would probably be looking at paying for someone experienced to do the work since this isn’t really a beginner project. So factor that into the cost of the boat also.
