It is currently Fri Sep 11, 2026 5:23 am
PostPosted: Mon Aug 15, 2011 12:32 pm
I just wanted to send out a big thank you to all involved..
I had a ton of fun and encourage any other new guys like myself to start hitting these regatta's. It is a bunch of fun and you will learn a lot while getting to meet some great people...
Thanks again guys.. I had a great time, and will be back again for sure...
www.thehobiewayoflife.com
PostPosted: Mon Aug 15, 2011 6:28 pm
thank you for coming. Hope to see you at more events. Most of the boats you saw will be down to Lawrence for your regatta!! Just hope its not snowing. Storm Lake, IA Regatta Sept 10-11. Its 4 hours from KC.
PostPosted: Tue Aug 16, 2011 9:24 am
I plan on making as many as I can.. Really trying to talk the wife into heading up to Clear Lake.. :D
And I am bringing my old beater boat.. I just need to find a comp tip mast to use.. probably redrill my epo's i have on the 18... Or something like that.. After I got home and started cleaning up my dads boat keeping in mind all of the things I had seen and heard over the weekend there is no doubt I will be faster next time for sure..
Besides being fairly heavy a number of tiny little problems added to to basically sailing around with the brakes on all day.. With dads boat needing a bottom job so bad we were probably losing some lift... :shock: and the side rails both somehow being bent down... Not being able to run enough rake due to the old 5:1 Seaway blocks which had a broken racheting gizmo making it very hard to fine tune the main in heavy air... Then the tiller nut was a little screwy all day... All those little things add up fast...
So much fun.... :D
