It is currently Fri Apr 26, 2024 2:23 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Tue Aug 26, 2014 7:56 pm
Thanks Matt for your response. One last question on this issue (promise): would you recommend or do you see any harm in installing longer bolts in the inserts, as was previously suggested, if the stock bolts are too short? Thanks!
PostPosted: Wed Aug 27, 2014 8:25 am
Would depend on the threaded inserts in the hull. I'd be surprised if they were not nearly fully threaded in, but maybe there was a fastener problem on some boat(s) if they are short. You would not want to bottom out in the insert and you would not want to drill through the back.
