It is currently Sat Aug 08, 2026 9:14 pm
PostPosted: Fri Aug 25, 2017 8:10 am
The central hinge point rivet on my Bravo (original design) mast hinge/gate assembly failed while underway last week. Luckily the "furler strap" was in place and actually kept the mast upright while I limped back to the dock.
I would like to replace the gate assembly. The part number on the Bravo parts guide says:
Hinge/GateAssy Original Style 90500021
However, when I search online for that part number, all the vendors that carry it have a picture of the new gate design. And the parts guide is pretty explicit about the new not being compatible with the old.
Can I get a replacement the gate assembly for the original design? If so, what is the part number and where can I buy it? If not, what are my options?
PostPosted: Fri Aug 25, 2017 8:17 am
That is the correct number for the old gate assembly. It has the bar and the hinge. The image is not showing the hinge.
90500021 MAST KEEPER GATE ASSY
PostPosted: Fri Aug 25, 2017 9:17 am
OK. Thanks. I'm still a little confused though because the one I have has two hinge points and two straight bars. (I wish I could figure out how to upload a picture here.) We bought our boat in May of 2012. Maybe I actually have the new design? What is the part number for the new part?
PostPosted: Fri Aug 25, 2017 9:52 am
The solid bar is the original.
Yes! The one with a hinge in the bar is the newer one.
The one you need is:
90500022 MAST KEEPER HINGED GATE ASSY
PostPosted: Fri Sep 01, 2017 4:12 pm
Center hinge rivet sheared off on my Bravo (2011 version) some years back. Used a clevis pin and ring ding as a replacement. Works fine. (If the hinge rivet went on you, this may be in store for you: I also had the screw that connects the vertical support tube to the A-Frame shear off another time -- that was more dramatic & I needed to lash the mast to the [broken] A-Frame behind an island, then hobble back to the beach.)
