It is currently Sat Aug 08, 2026 8:24 pm
PostPosted: Tue Jun 12, 2007 1:34 pm
After several hours of sailing I end up with several cups (more than I think should be there) worth of water in the starboard hull. Anyone have any idea where that water could be coming from?
Drain plugs both seat well and are tight. I seriously doubt that much water could be coming over either of the front or rear storage compartments, I"m not sure if those seams drain into the hulls?
Although I do get the bow leeward carrying handles into the water when hiked out.. it doesn't seem as those could be leaking? Where else could it come from?
I don't think these hulls 'breathe' like the fiberglass boats do they? Any ideas?
'08 Hobie Wave, Hobie Adventure Islands
 Post subject: Leak?
PostPosted: Tue Jun 12, 2007 1:44 pm
You can do a leak test as shown in this forums FAQ (top - topic).
Check all fittings. Check the inboard side of the hulls. There is a small cap adheared over a vent. Maybe loose?
