It is currently Sun May 05, 2024 8:31 am
 Post subject: Rebuild of Mast Furler
PostPosted: Thu Aug 20, 2020 11:28 am
I just acquired a 2005 Hobie Bravo (which I love) that had been sitting for at least 10 years. The furling part of the mast seems to be hard to turn. I have used a pressure washer (with soap and water) and a dry lube spray. It still seems to not work properly based on Youtube vidoes I have seen. If you have taken it apart and rebuilt or have fixed this problem another way, please let me know. Thanks.
PostPosted: Fri Aug 21, 2020 5:08 am
Perhaps some penetrating fluid for a while before adding the lube? May not help at all but it's cheap to try before you have to take stuff apart.
PostPosted: Wed Aug 26, 2020 11:18 am
The ball bearings could be damaged. Replacing them would require removing one of the collars. That requires removing (Drilling) 4 stainless rivets.
8010131 RIVET POP 3/16x3/8 PH-SS (4)
90610112 90610112 DELRIN BALL 3/8 DIA (PKG OF 12)
US$ 9.19
You need 48 bearings total 4 sets.
