It is currently Wed Aug 05, 2026 10:27 am
 Post subject: hOBIE 21 SE TAPER PINS
PostPosted: Sat May 22, 2010 10:53 am
DID ANYONE GET THE PHONE NUMBER AND CONTACT PERSON FOR THE MACHINE SHOP TO MAKE SOME OVERSIZE TAPER PINS FOR THE HOBIE CAT 21 SE.
DOES SOMEONE OUT THERE NEED SOME ALSO
IF ONLY I COULD GET HOBIE TO BRING BACK THE KISSME RUDDER CONNECTORS WHICH ARE STILL THE BEST I HAVE EVER SEEN
PostPosted: Sun May 23, 2010 8:41 pm
I'm starting to get some play in mine and need to do something soon. Its either oversized taper pins or weld the holes and re-drill them to the right size. Do you have the dimensions for the larger pins? I worked with a shop on Merritt Island that could make them. From checking other posts, the bearing straps at the end of the crossbars need to be checked also or else putting new taper pins will not help for long if the bearing have gone bad. 8)
_____________
Jetblast
H21SE
PostPosted: Mon May 24, 2010 5:22 pm
The M20 style are even better. Rigid connection and easily removable tiller crossbar. Standard on the current H16, Tiger...
Kit is # 1953.
PostPosted: Tue Aug 03, 2010 4:55 pm
Hello,
Yes, I'm also interested in some oversized tapper pins. The front holes on my crossarms are approx. 23/32 nds of an inch. and the back holes are approx. 5/8 inch. I'm thinking if the larger end of the pins are large enough they will fit most holes as long as they have the right taper. We must also account for future wear. I plan on reaming my holes a little to get down to some new metal for a tight fit.
So anyway I'm interested if this is something close to what you have been considering.
Wayne
