It is currently Wed Aug 05, 2026 11:26 am
 Post subject: Parting out 21 SE
PostPosted: Sat Jan 26, 2013 7:51 am
A commmon refrain: No mast replacement. My mast broken during severe weather last year, last option is to part out the 21SE. No mast, no wings, jib furler damaged, no mainsail. I also did some "creative" rigging on the traveler to keep the car on the track (easily set back to original).
 Post subject: Re: Parting out 21 SE
PostPosted: Wed Jan 30, 2013 1:03 am
I could use your rear X-beam.
Bille
Edit : Nevermind -- was given a Better solution ; your
aluminum is no longer needed.
PostPosted: Sun Mar 24, 2013 8:02 pm
Are the wings completely gone or just damaged? I have a bent leg on one of my wings so need a replacement.
PostPosted: Mon Mar 25, 2013 9:55 am
If Ya can't find it then post a picture of the bent one ...
maybe someone can tell Ya how to fix it.
Some quite ingenious people on this forum !!
Bille
PostPosted: Mon Mar 25, 2013 12:05 pm
I have a wing for sail.... can be for ether side. new never drilled. look for it in the thebeachcats.com
Rick Dougal
Port Orange, Fl.
H18 want to be SX
H21SE
PostPosted: Tue Jul 02, 2013 4:40 pm
I was able to get a new leg so wings are good now.
Do you still have the boom? Mine still works but it's in rough shape. The end cap is on the gooseneck side is held on with several stainless straps because it busted out and the outhaul doesn't appear to be working properly. The gooseneck pin is also very sloppy. I think a new end cap, goosneck pin, and rework of the outhaul might resolve things. Would the H18 boom endcap work on the 21SE boom?
