It is currently Wed Aug 05, 2026 2:09 pm
 Post subject: cat trax
PostPosted: Mon Jan 03, 2011 6:39 pm
looking for info on cat trax for 21se i just bought new set last summer for my h18 but I dont think they will be wide enough for the 21 what are you guys that have trax using is their a longer pipe or do i make something???? I see them advertised to work on h 20 which is 8'6" wide 21 is 9' 6' wide
thanks for any input I cant wait till the water gets softer up here in NY
Ted
Hobie 21se
feral cat
 Post subject: Re: cat trax
PostPosted: Mon Jan 03, 2011 7:30 pm
Ted,
Check out page 11 of the catamaran parts for sale on the beachcats.com and you will see two cat trax for a 21 for only $4oo.Mine cat traxs are 1989 and still look new and having two would spread the weight much better.Location,NH which is ? close to you.. :D .
I am not trying to promote the completion but I am trying to help.
good luck Bill 404 21SE
Bill 404 21SE
PostPosted: Wed Jan 05, 2011 5:47 am
Bill 404 wrote:
Ted,
Thanks bill I just emailed him wil see if they are still available, then i could sell my new trax with the 18 rather then new axle.
thanks
Ted
Hobie 21se
feral cat
PostPosted: Fri Jan 07, 2011 10:09 am
Two sets of cat wheels will spread the load but turning will be hard
My rubber tire cat wheels do just fine
PostPosted: Fri Jan 07, 2011 10:25 pm
hey Gary thanks for the thought I have a set of cat trax I use on my 18 and they worked just fine so am looking for the extension or a new set for the 21
Hobie 21se
feral cat
PostPosted: Sat Jan 15, 2011 5:39 am
i spoke with the gentleman from catrax and found out it is a $ 50 axle extension that i can use with my existing trax so will plan on doing that. anyone have any favorites on hull cradles for the trax, and the 21 who makes the beter set or should I make my own when i am doing my repairs?
Ted
Hobie 21se
feral cat
PostPosted: Sun Jan 16, 2011 2:42 am
Ted,
Just order those cradles from catrax when ordering the axle extension.They work well and will last.
I fabricated a "Z" channel from 1/8 aluminum walk plate that I bolted to a aluminum tool box under my boat on the trailer.This "Z" channel holds my catrax out of the way and on aluminum so no rusting between dissimilar metals.This tool box is design to fit under a fifth wheel set up in the truck bed,low profile design.It is a great place to keep extra gear already loaded on the trailer and the weight over the trailer axle. :D
Bill 404 21SE
Bill 404 21SE
