It is currently Wed Aug 05, 2026 9:25 am
PostPosted: Tue Jul 26, 2016 3:42 pm
Are the Hobie 21 SE rudder castings (upper & lower) compatible with the H21 SC or Getaway castings?
I'm looking for 1 casting. Finding a casting off a H21SE is proving to be difficult, so thought maybe I needed to expand my search depending on compatibility.
Thanks!
PostPosted: Tue Jul 26, 2016 4:20 pm
The Hobie 21SE used the same castings as:
Hobie 17
Hobie 18 1985 and newer
Hobie 20
Hobie Wave and Getaway until we went to EZ Lock (plastic housings)
PostPosted: Tue Jul 26, 2016 5:01 pm
Hi Matt,
Thank you for your quick reply! Great to know that there are other casting out there available rather than just for the H21SE.
PostPosted: Sat Aug 13, 2016 3:32 pm
So if the casting is the same will the one piece H18 die cast gudgeon work? Part # 60102011 for example. Looking to repair and upgrade my transom.
Scott
Hobie 18 w/wings
Hobie/Holder 12 Funseeker
2 Hobie Waves
Tandem Oasis Kayak
Hobie 16
Southern California
PostPosted: Sat Aug 13, 2016 5:12 pm
Same casting just a longer "arm" to the crossbar connection....I have replaced both upper unit a couple of years ago...not bad for sometime for '89... :)
Bill 404 21SE
