It is currently Wed Aug 05, 2026 9:25 am
 Post subject: Outboard
PostPosted: Wed Oct 18, 2017 5:12 pm
How big of an outboard can I put on my 21sc?.
Sent from my SM-G930P using Tapatalk
 Post subject: Re: Outboard
PostPosted: Wed Oct 25, 2017 12:49 pm
I would recommend the lightest, smallest outboard you can find.
I have a 2hp, 2 stroke outboard. It works well at half throttle. At full throttle the prop pitch is too steep and it just cavitates.
Boat speeds at half throttle are ~6mph. Not bad considering many monohulls with inboards top out at 7-8mph.
My biggest complaint is the motor is too heavy. It is slightly difficult to install, raise and lower. If someone made a 1hp motor with a shallower pitch, and sold it to me for $100, I would buy it.
~Joe
PostPosted: Wed Oct 25, 2017 3:59 pm
Isn't the motor bracket rated up to 29 lbs. :?
Bill 404 21SE
PostPosted: Thu Oct 26, 2017 7:38 am
My motor weighs less than ~25lbs. I am just weak and lazy. Plus it can be awkward to raise and lower the motor mount while in the water if the motor is too heavy.
PostPosted: Sat Oct 28, 2017 6:10 am
Probably get the honda 2.5 shot shaft then. Going to long beach in November and I want to make sure the motor can push it nicely with a full crew.
PostPosted: Sat Oct 28, 2017 6:23 am
What did you end up doing with your comp tip?
PostPosted: Sun Oct 29, 2017 6:34 am
The Honda 2.3 hp will have no problem pushing a fully loaded TI at less than half throttle and will use about 1 liter every two and half hours.
PostPosted: Mon Oct 30, 2017 5:17 am
Define "full crew"
I usually sail with 4 people on the boat, and have never felt under powered with 2hp.
I have sailed it on a calmer day with 10 people. The outboard had no issues pushing us up the canal between Lake Michigan and Lake Charlevoix.
I would like to replace it with a Hobie Tiger Mast, but I can't seem to get my hands on one. If nothing turns up, I will build a carbon fiber sleeve and splint the mast back together. The old comp tip had no visible damage and was not loose prior to it's failure. As such, I can't justify spending a bunch of money getting a new comp tip that could also fail without warning.
~Joe
