It is currently Wed Aug 05, 2026 9:24 am
PostPosted: Sat Apr 27, 2019 4:52 am
Just picked up a 21se and plan to replace the rigging with a set from salty dog. I know this has been discussed many times over but I’d like to add shroud extenders to assist with righting.
I prefer the hyfield lever for ease of reconnecting the rig but they only extend about 3”, I don’t think that would be enough to allow for solo right even with a bag, am I wrong?
The Hobie extenders would do the trick but getting them reconnected on the water looks sketchy. I was thinking I could add some micro blocks and cleat to the shrouds to add tension while I reconnect. Has anyone ever tried this?
What are opinions on a mast bob? Logic assumes an extra 5lb at 33’ takes an additional ~165lbs to right, is this correct? I’ve read bill404 has a self inflating vest up top which sounds like a great solution.
PostPosted: Sat Apr 27, 2019 7:38 am
Maybe use both the hyfield and the hobie extension. Hyfield will make it easier to release the and re-tension to the final rig load. The hobie extension will give the length needed to assist with righting.
PostPosted: Sat Apr 27, 2019 10:15 am
I have used both for 30 years now.............. :shock:
Bill 404 21SE
PostPosted: Mon Apr 29, 2019 2:05 pm
Yes, you need the extensions to get the length needed. The levers just allow you to re-tension the rig on the water.
PostPosted: Wed May 01, 2019 9:57 am
Thanks for the input guys.
I just ordered replacement shrouds and decided to just go with the shroud extenders. I plan to add a line to trap wire to to take slop out of rigging while I reconnect.
PostPosted: Wed May 01, 2019 11:19 am
Don't forget that your new shrouds will need to be made shorter to allow for the extensions to work right.... :wink:
Your new shrouds should be made 8.25" shorter that the original length.
Bill 404 21SE
