It is currently Wed Aug 05, 2026 9:24 am
PostPosted: Tue Oct 15, 2019 3:50 pm
Hey guys,
The mast base on my 21sc had a piece sheared off by previous owner and I replaced it with the correct part ( 36641031). However, when inserting the pin now to hold the mast base to the ball, it will not fit past the ball.
Anyone run into this?
PostPosted: Thu Oct 17, 2019 9:02 am
Damaged ball or miss-aligned hole / bent pin? You can drill the hole a bit larger.
