It is currently Wed Aug 05, 2026 10:25 am
 Post subject: 21se gudgeon is bad
PostPosted: Tue Mar 31, 2020 11:21 am
The transom has gone soft and lower gudgeon has broken the glass. I intend to dry it out, drill holes, inject epoxy, reinforce inside and outside of transom with glass (prob some heavy carbon mat on the inside) and then thru bolt it back together. Should be fun. Does anyone know if the part linked below is compatible? It seems like a sensible step up, esp since I'm fixing the area anyway.
https://www.murrays.com/product/50-60102011/
Thank You.
 Post subject: Re: 21se gudgeon is bad
PostPosted: Tue Mar 31, 2020 4:32 pm
Should be. It is the same lower rudder casting and gudgeon arrangement on the 18 and 21.
PostPosted: Tue Mar 31, 2020 7:18 pm
I've got extra stock type if you need it. Not like that, though...
ChuckC
H21SE- 408
PostPosted: Tue Mar 31, 2020 7:21 pm
What I have is like this:
https://www.murrays.com/product/25-3352/
ChuckC
H21SE- 408
PostPosted: Wed Apr 01, 2020 8:30 am
Thanks, but I have the orig style to reinstall if necessary. The one piece model looks more solid and better for alignment.
