It is currently Wed Aug 05, 2026 1:27 pm
 Post subject: Question about Comptips
PostPosted: Wed Dec 12, 2007 7:39 pm
I would like to run the halyards inside the mast. Before I drill any hole I would like to know whether the comptip is empty or filled with foam.
PostPosted: Wed Dec 12, 2007 8:35 pm
Is there enough room for it to run back down through the sail track?
PostPosted: Fri Dec 14, 2007 4:06 pm
I'm pretty sure it's foam filled...I should be able to tell you in about 2 weeks when I pull the mast head off of mine....
TC
PostPosted: Fri Dec 14, 2007 9:22 pm
Authorized Hobie Dealer
they are foam filled, not sure you'd be able to run them inside.... Can't it run back down the sail track like Karl mentioned
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
 Post subject: Filled? No.
PostPosted: Mon Dec 17, 2007 10:06 am
CompTips are sealed with foam, but not filled. There is a large hollow space between the top and bottom foam plugs.
PostPosted: Tue Jan 01, 2008 6:12 am
If there are plugs on the top and bottom of the comptip, running the halyards inside would make that area "floodable". Not good.
Thanks for the info and Happy New Year to all!
