It is currently Wed Aug 12, 2026 2:38 am
PostPosted: Fri May 27, 2011 9:42 am
Greetings,
Yesterday I was installing the accessory holder kit to my new i14t along with the RAM post scotty conversion and the hole where the l mount the ram mount cracked. What are my options? I am disappointed in the quality of the accessory holder kit not to mention the lack of instructions that came both with the holder kit and Hobie Ram Mount. Is there a way to safely remove the accessory holder?
PostPosted: Tue May 31, 2011 3:59 pm
The Scotty mount cracked? You should be able to unbolt this from the accessory mount. A new one can be bolted in it's place. That is a thick piece of plastic though. Surprised it would crack.
The accessory holder is a contoured plate with 4 embedded nuts that glues to the hull.
The Scotty mount bolts to the plate.
The RAM ball inserts into the Scotty mount.
