It is currently Sun Jun 15, 2025 2:37 am
 Post subject: HCCBM300J819 HOBIE i11s
PostPosted: Mon Jun 09, 2025 12:59 pm
The starboard outer top panel seam has begun to delaminate and is leaking air pressure. What is the best way to patch a seam?
Hobie Fishing Team Rider
Stay Fit, Go Fish, and Have Fun
SpinfisherBob
http://www.youtube.com/user/SpinfisherBob
PostPosted: Tue Jun 10, 2025 3:28 pm
https://youtu.be/nGS9vM53CX8 Here is the issue.
SpinfisherBob
PostPosted: Tue Jun 10, 2025 6:23 pm
There are a ton of patching youtubes, I think the most detailed from the NRS channel. I think the Hobie channel has one or two but as I recall seem to be hobbled by the California ban on proper glue. From my limited experience of sealing a non-Hobie seam leak, I used one of my umpteen patch kits that predated the CA-compliant contact cement. Mine melted the 2 bladder and one deck pad together and allowed it to hold the substantial 10psi.
The powerful glues can still be ordered online as well as various pre-cleaners etc. They supposedly expire rapidly altho my expired stuff worked. I gather Hobie is made of PVC in case you look for compatible glues. The contact cement may work fine for patching a smooth surface, but good luck for a lumpy seam. I think I didn't end up even using a patch since it looked so solid. Be aware there are also liquids you can pour into the valve and slosh around as a last resort if you can't get rid of tiny pinhole leaks.
