It is currently Wed Aug 12, 2026 2:38 am
 Post subject: Pump
PostPosted: Sat Mar 28, 2009 2:38 pm
Whats the process for greasing or lubing the pump? Mine is getting noisy.
PostPosted: Mon Mar 30, 2009 9:22 am
I'd try cleaning the shaft with CLR or Lime Away first. If that doesn't work, I am sure that graphite would probably be a good lubricant for it.
PostPosted: Mon Mar 30, 2009 4:21 pm
Authorized Hobie Dealer
a shot with some dry silicon should do the trick.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
 Post subject: Re: Pump
PostPosted: Fri Dec 04, 2009 11:24 am
My pump was extremely loud and difficult to operate after 8 inflates. I took it apart to find that it was filled with dirt and grime -- not sure how that happened. I cleaned the head of the shaft and the inside of the barrel, then added some silicone grease to the shaft head. It's like new again.
John
