It is currently Wed Aug 12, 2026 2:38 am
 Post subject: assembly questions
PostPosted: Mon Feb 15, 2010 2:52 pm
Hello to all!! I'm very happy cause finally I brought home my new i12. When I was trying to assembly the drive I found the left steel drum shaft like 1 inch out. Looks like the right one is on the correct place. (see picture). My question is how can I put it in without damaging the unit? Is very tightened!!
Later more comments about my new kayak.
 Post subject: Re: assembly questions
PostPosted: Mon Feb 15, 2010 4:26 pm
Use a mallet and pound the shaft back to center. Likely the drive was dropped on its side or impacted to push the shaft out like that.
PostPosted: Mon Feb 15, 2010 6:27 pm
Ok, Thanks!!! I'll do that. Looks like my i12 has a really bad time during the shipping process, in some how I think it suffers a hard blow. I found a hold in the travel bag exactly where the drive was.
Also, the first time I try to rise the bag from the side straps the bag. Well, I hope I find the rest working well.
PostPosted: Thu Feb 18, 2010 9:57 am
Matt:
Is it really that easy to center the shaft? When i had my drive disassembled I got the impression that the shaft was very solidly bonded to the center drive structure somehow and I have a hard time seeing how the shaft would stay put at it's new position after having been pounded into place.
PostPosted: Thu Feb 18, 2010 10:21 am
Yes... that easy. Newer drives have lateral splines, but there is no "bond" other than friction.
PostPosted: Thu Feb 18, 2010 11:56 am
That's really nice to know since the shaft of one of my drives have been somewhat off center since I bought it. Not enough to disturb function but I suspect that it might have caused the drum to rub against the hull from time to time giving rise to a squeeking noise.
