It is currently Wed Aug 12, 2026 5:42 am
PostPosted: Fri Feb 04, 2011 4:39 am
Hi
I bought the accessory plate that is used to mount accessories onto the i9s.
My question is, once I glue this plate on, is there anyway to remove the plate (any glue remover?) from the inflatable kayak without damaging it ?
Or is it once glued on, you can never remove it ?
PostPosted: Fri Feb 04, 2011 11:25 am
Once glued on... that is it. You could remove, but you would have to cut and or grind off the plate and that would be difficult let alone potentially damaging to the boat.
