It is currently Thu Aug 13, 2026 5:40 am
PostPosted: Mon May 30, 2011 1:05 pm
I purchased a i12 in late summer 2010 and am now using it as a tender for my sailboat presently cruising in Puerto Rico. I have had a slowleak in the port chamber since purchase, but have not been able to locate the source. The leak recentely incresed significantly so that it defates approximatley 1/3 in 10 minutes. I reran the leak tests from the manual and found that the valve is leaking.
1) How can I remove/ tighten the valve without the special tool mentioned in the manual?
2) How do a arrange to get a replacement valve?
I can be most easily reached at [email protected], however the website login would not let me use that email address.
Bob H
