It is currently Sat Sep 12, 2026 6:50 pm
 Post subject: i11s as SUP
PostPosted: Sat Jun 03, 2017 5:59 pm
has anyone tried using the i11s as SUP? how does it compare to other inflatable SUPs? Don't want to pull the trigger on getting a paddle if it is not really that well, seems a bit wide also where does one stand?
-i11s Newport Beach, CA area.
 Post subject: Re: i11s as SUP
PostPosted: Mon Jun 05, 2017 9:21 am
The i11 works great as a sup conversion...and standing on the factory EVA standing pads is a good place to stand for a balanced ride...with the seat removed you can theoretically move up and down the board depending on your comfort level and maneuverability you want to achieve.
Howie Strech
PostPosted: Tue Jun 06, 2017 9:32 am
Thanks for the answer.
Tried it on Sunday, does seem pretty good except when it hits waves, somewhat not as rigid as I hope. Also slight pool of water where the side hulls hit the main deck, near the center. I have tried the old Sportsman SUP before, which seems similar to the i11s in SUP form, very similar based on the stats and picture below. That one the PSI is a lot higher, almost 3 times. Would it be possible to pump the i11s higher than the recommended PSI or is that not recommended considering the construction is different?
One last question, do Hobie sell extra pads I could glue on? What is the part number for that? Thanks!
https://www.hobie.com/sups/outdoor-i-series/
PostPosted: Tue Jun 06, 2017 5:24 pm
not recommended to go over the psi rating on the i11s...and we don't have a specific pad kit for the i11, but a SUP kit might work for you (if you're okay with doing some trimming). Maybe somebody else in the forums has given this a shot?
475205-33
HOBIE 8PC SURF SUP PAD-GREY
US$ 110.00
Howie Strech
