It is currently Fri Sep 11, 2026 1:40 pm
 Post subject: Why a bilge valve?
PostPosted: Fri Dec 01, 2017 8:54 am
Hey guys.
Owner of a brand new i12s here. If the bilge valve is there only to equalize atmosphere in the hull during inflation/deflation... I get it. If it is for draining water out I will not be a happy camper. How is water ingress even possible unless the boat is damaged? Just curious...
i11S because, "Charlie don't sail"
 Post subject: Re: Why a bilge valve?
PostPosted: Mon Dec 04, 2017 9:07 am
Mostly for the air pressure equalization issue during inflation and deflation. And of course can be used as a drain if you did get a leak by puncturing the bottom material.
PostPosted: Tue Dec 05, 2017 3:42 am
Thanks Matt. I will never need to drain the bilge. The stiff rubber keel made folding the i12s such a chore I talked the dealer into swapping for the i11s. 8)
