It is currently Fri Sep 11, 2026 9:23 pm
PostPosted: Mon Sep 03, 2018 9:20 am
Hi,
Are there upgrade fins for this V2 Mirage Drive?
a retailer says we have to upgrade the whole drive. I see i series upgrade fins labeled V2 in the current parts and accessories catalog.
https://photos.app.goo.gl/SyhuiCfj7uMSZErf6
https://photos.app.goo.gl/bvknHVtfPSy1zd4K6
https://photos.app.goo.gl/4TUAge7cFEURy4xY8
https://photos.app.goo.gl/hWgdZyZFa5i2r2qH7
PostPosted: Mon Sep 03, 2018 7:12 pm
Based on your photos, you presently have the "comfort fins" on V2 Mirage drive.
I think to upgrade to the ST Turbo fins, you need 2 new threaded masts P/N 81198101 and 2 new ST Turbo fins P/N 81192001 (Gry/Blk)
and some Blue Loctite P/N 8000341
For the smaller ST Fins, your present masts are used and replace with 2 new ST fins P/N 81193001.
In one of your photos, the idler pulley cable is missing some of the black plastic cover, so replace it with V2 P/N 81203001.
If you wanted to go "whole hog" and upgrade to the "GT Sprocket", then Hobie has a kit for that, P/N 81129123, GTT Turbo Mast kit.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Sep 03, 2018 7:54 pm
must be glare from the flash. both drives look the same except for serial number (2 I9 inflatables, new old stock from a hobie dealer)
thanks for your reply
PostPosted: Mon Sep 03, 2018 7:56 pm
Dr.SteelheadCatcher is correct and your retailer is not. All you need are V-2 masts and ST Turbofins if you want Turbos, or just fins if you want the smaller ST fins. The Turbo upgrade kit (masts, fins and Loctite Blue) is 72066001 (gray/bk fins), 72066021 (red/bk), or 72066031 (Blue/bk).
PostPosted: Tue Sep 04, 2018 9:27 am
Just to be clear, the retailer was Austin Kayak and the discussion was through email.
I have noted that others have had odd discussions with them through this method.
thanks for your help
