It is currently Fri Sep 11, 2026 7:16 pm
 Post subject: i-series rudder control
PostPosted: Thu May 11, 2017 2:34 pm
I'm looking for a part number for the i-series rudder control that mounts on the side of the Vantage seat...I need to order an extra one for a project I'm working on...cheers, roger
2019 Outback360 'Fish Retriever'
2016 i11s 'Go Cougs!'
2012 Oasis and 2012 PA12 (moved on but not forgotten...)
PostPosted: Thu May 11, 2017 3:30 pm
Those are part number 84501401 (this is the base number they're $9.19) any dealer can obtain this item for you.
PostPosted: Thu May 11, 2017 5:21 pm
thanks, is that just the steering handle? I am looking for the round rudder control unit for an i-series that mounts on the side of the Vantage seat...I sure hope it's only $9...lol
PostPosted: Thu May 11, 2017 5:36 pm
This is just the bottom round part with slots on the bottom and two small pulleys.
PostPosted: Thu May 11, 2017 6:22 pm
great, that sounds like what I'm looking for. thanks.
PostPosted: Sat Jun 09, 2018 6:59 am
Glad to see this post. The base of my rudder control (the thin plastic bridge) broke at the front of the mounting channel. This is a very fragile design. The base should be made of cast aluminum or the channel mount should be completely redesigned to make it much stronger.
PostPosted: Sun Jan 17, 2021 11:18 am
I just had to replace my lower housing as well. It cracked where it slides over the bracket on the side of the seat. This really should be made out of a stronger material!
