It is currently Wed Jun 24, 2026 2:44 am
PostPosted: Tue Feb 24, 2015 6:35 pm
I am looking for mounting suggestions to allow "Lowrance Elite 4 HDI" viewing/ control from either front or reas seat on 2015 Hobie TI. TI and Lowrance are both on order. Thanks for your best ideas!
PostPosted: Fri Feb 27, 2015 9:15 am
This morning I made a hybrid stand which is suitable for fishfinders with lighter weight :)
1. 72023021 FISHFINDER MOUNT II
2. 72023032 CAMERA MOUNT 18” ARMS (PAIR)
3. 72020054 SCREWBALL 1-1/2”, 1/2” MIGHTYBOLT
4. 86505621 HOBIE THRU HULL WIRING KIT
5. 72020057 GEARTRAC-8”, 2 PACK W/ MOUNTING HARDWARE
This is my setup:
RailBlaza:
1. 02-4030-11 PlatformBoom 150
2. 03-4001-11 StarPort Pair Black
YakAttack
3. Knob - 1/4-20 Threads - 6 pack
3. MB15-12-6 - MightyBolt - 1-1/2" lg - 1/2 wide - 6 pack
Hobie:
4. 72020057 GEARTRAC-8”, 2 PACK W/ MOUNTING HARDWARE
5. 72020054 SCREWBALL 1-1/2”, 1/2” MIGHTYBOLT
6. 72023035 RAM 18” MOUNT TRANSDUCER
RAM
7. RAM SINGLE SOCKET ARM WITH OCTAGON FEMALE
But this is for fishfinders with bigger display, because the PlatformBoom 150 is too short.
I swapped the standard ball 1” with 1-1/2”, because in this way transducer is much more stable.
PostPosted: Fri Feb 27, 2015 3:58 pm
I use a similar setup, just with the railblaza extension/swivel arm platform.
http://www.railblaza.com/products/platf ... ro-series/
Mine is mainly for rear seat use; depending on where you put the starport on the hull you could probably see it from the front seat.
-RH
2013 Tandem Island "Victory Lane"
Oahu, Hawaii
www.rotorheadsblog.blogspot.com
PostPosted: Thu Mar 05, 2015 9:11 am
Thanks for the pics and ideas JB and RH! Your pics and descriptions gave me the info I needed to select. Because I have a smaller Elite 4 HDI I ended up going with:
1. 72023024 FISHFINDER MOUNT III for Elite 4 series
2. Dogbone extender pole which uses Ball connects on both ends.
2015 TI is already fitted for through hull wire and transducer connects. The TI should arrive within a month!!!
PostPosted: Thu Mar 26, 2015 9:49 am
Do any of you guys use a backing plate on the Geartrac with such a long arm?
