It is currently Wed Jun 24, 2026 12:29 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: A.I. mini-mods...
PostPosted: Tue Dec 24, 2013 5:16 am
Sweet mod...that one goes in today!
Wife won't mind a hole in her yoga mat will she?
PostPosted: Tue Dec 24, 2013 7:49 am
Ditto, but with a scrap of closed-cell foam carpet/tile underlay! :wink:
Wise men still seek Him! :)
"Take life seriously................it's eternal in one of 2 places - you choose!" :) :(
PostPosted: Tue Dec 24, 2013 1:06 pm
I just found this post regarding the front hatch seal check it out excellent idea.
viewtopic.php?f=32&t=48684#p219696
PostPosted: Thu Dec 26, 2013 2:34 pm
Here's another mod I found on the forum that is suitable for this post.
Scupper hole drain.
viewtopic.php?f=71&t=45380&p=222298&hilit=Scupper+drain+siphon#p222298
PostPosted: Tue Jan 12, 2016 11:32 am
More Hand-Friendly Mirage Drive Bungee
A six-inch piece of garden hose over the Mirage Drive bungee makes it quicker/easier to hook/un-hook.
viz: https://picasaweb.google.com/1081497986 ... 6838037506
A bicycle handlebar grip would probably look/work better.... but I had the garden hose...
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Sat Jan 16, 2016 7:14 pm
More Hand-Friendly Front Hatch Attachment
Maybe I should start a third thread "Micro Mods".... -)
I find that removing/replacing the front deck hatch becomes significantly easier after supplementing the webbing tabs with a couple of rope handles:
https://picasaweb.google.com/1081497986 ... 3501742802
https://picasaweb.google.com/1081497986 ... 3914110162
Red, of course for port and green for starboard....
PostPosted: Sat Jan 16, 2016 8:22 pm
Pete I love those webbed tramps! I could use those for the upcomming Texas 200. How are they working g
out?
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Sun Jan 17, 2016 8:29 am
vetgam wrote:
...webbed tramps! ... How are they working out?
Just one tramp so far - on the starboard side.
So far, so good. My 215# of lard has not succeeded in breaking it and I had it out on Sunday when it was gusting over 25 mph and did not notice any additional tendency to pitchpole or capsize.... there probably was some, but I did not perceive it.
I did wind up ripping the stitches out and re-sewing the cross straps.
Reason: If you lay it all out on a nice flat floor, staple the strap intersections just so, sew it up, and then mount it between the akas and apply tension it all goes South....For reasons not apparent to my spatial relationship-challenged mind, the fore-aft straps on each side assume a slightly curved shape - introducing slack into the cross straps.
The cure was to turn the boat on it's side, rip the stitches, and the re-staple the cross straps nice and snug with the fore-aft straps under tension - in their native curved state.... and *then* sew it all back together.
I also added little circles of line around the fore aka to keep the straps from wandering port-starboard....although, in retrospect, it seems not needed.
Here are a few pix of the latest iteration where you can see the curves:
https://picasaweb.google.com/1081497986 ... 6019012050
The next step will be to try to get rid of that d-ring interface between the two sections (held together by the yellow line). ..... It's there because I was not confident in my ability to get all the straps attached with uniform lengths...but it turned out the d-ring spacings under lashing were identical, so I am hoping I can get rid of them.
I just made another mini-mod by lashing a block on to the forward mainsheet cheek block to make the 3/16's sheet run more freely and give some angle adjustment when I am sailing without the cleat..... Then, come warmer water/weather, the first thing I will try is sailing in outrigger canoe mode - sitting on the tramp with the block allowing the cleat-less mainsheet to run freely at the different angle. Steering is still up for grabs, but I see plenty posts showing various solutions....
PostPosted: Sun Jan 17, 2016 10:18 am
pretty slick! Maybe you can even intentionally collapse an ama with that in place?
PostPosted: Sun Jan 17, 2016 6:27 pm
Tramp looks smoking hot to boot. Love to see what people come up with for mods on this forum. Mods are at least half the fun. That's the beauty of a roto molded trimaran. Like working with Legos at age 57.
Greg
– Charles G. Davis
PostPosted: Sun Jan 17, 2016 7:10 pm
True, dat...
And whenever I piss and moan about the shortcomings I perceive in my AI; somehow I neglect to report all the hours of amusement I have had thinking about and fooling around with modifying it.
I have to wonder if it's some sort of personality quirk.
PostPosted: Tue Jan 19, 2016 11:54 am
Cover Akas with Windsurfer Boom Grip
viz: https://picasaweb.google.com/1081497986 ... 9275749810
Ball-peen hammer for dramatic effect....
  • Better grip if/when...
  • More hand-friendly when it's cold
  • No more concerns about scratching/scraping/banging during storage/transport
Not too bad looking in spite of the nasty seams around the curves.
