It is currently Tue Jun 23, 2026 10:40 pm
 Post subject: Trolling motor for TI
PostPosted: Tue Sep 30, 2014 1:34 am
I've been considering adding a trolling motor to my TI and decided to go with an electric motor. I do not expect to be zipping around with a trolling motor. I would like something that can be used to slow troll and assist with getting to and from my beach launch area and where I fish.
I have been looking at: http://www.islandhopperoutboards.com/kayak-trolling-motors.html
They have 30lb, 46lb, and 56lb thrust models. I could see going with the most powerful motor since the TI is so heavy on land but is it necessary to have that much thrust to push it in the water
I'm curious if someone has tested any motors of similar thrust with their TI or could give a suggestion for what is needed to propel the TI
Thanks!
PostPosted: Tue Sep 30, 2014 5:46 am
This is just my opinion of course but I do not see any advantage at all to mount a trolling motor into the mirage drive well.
There are plenty of posts on here that show how to make motor mounts for TI's, and also island hopper sells them if you don't want to make your own.
Once you have a motor mount you can mount any motor you like on the boat, if it was me I would go with the cheapest possible (like under $100 dollar motors at Walmart). Basically you would keep the motor tilted up on the back of the boat, then just swing it down when needed. If you have a trailer there would be no need to ever remove the motor or batteries from the boat (that's what I do with my outboards, the just live on the boat and have never been removed).
99% of the time the motor would be locked straight, and you steer with the boats rudder. If the rudder were ever to break for some reason the motor becomes your back up steering.
Yes you can get huge batteries for more range, but the way you discribe your needs, one or two 25lb ATM batteries will probably do you just fine, again if you have a trailer they never need to be removed from the boat. I would just store them on the rear deck in battery boxes lashed down.
Of course you can get as fancy as you want with I-pilot remote control systems and such but why....you just using it locked to get you in and out of harbor 99% of the time. If you want to drive from the front seat it's pretty easy to make a tiller extension that reaches up to the front from a piece of $3.00 PVC pipe (that's what I have).
90% of the time the motor will be just tilted up harmlessly at the back of the boat, you can just put a bag over it to keep it dry (that's what I do). I have seen quite a few people using fresh water motors in salt water, as long as you rinse it off well after each use it should last a while (not forever though, but you will likely get a few years out of it as long as you rinse it every time).
The TI is only a couple hundred lbs and glides easily in the water even a 30 lb trolling motor will push a 16 ft 2000 lb bass boat with ease, one misnomer about trolling motors is people buy a 55 lb thrust motor on small boats thinking it will go faster, in reality you don't go faster (well maybe 1 mph faster), but you use much more battery power way faster. Most cheap trolling are most efficient at near full throttle if operating at 1/4 throttle you are just wasting the battery dumping the excess power into resisters and heat sinks unless you have a fancy pwm controller (only on the expensive motors). Yours will be either on or off, you won't have a big need to crawl very slow (like trolling) you are just using it for basic propulsion and that's it.
If it was me I would just get a 30 lb walmart special motor for under $100 bucks and adapt it to work. A home made motor mount is only $15 bucks in materials (plenty of posting on how to make).
Two ATM batteries will be about 50 lbs, and the motors are about 15 lbs, you don't notice that extra weight on the TI at all. Actually mounting everything aft actually helps on a TI (you want as little weight as possible in the front of a TI FYI).
Besides, if you get a mirage slot mounted motor, where in the heck would you put it when your not using it ( nobody has thought that one thru (lol)) plus you lose the use of the pedal drive (the #1 feature of the boat).
Keep in mind the TI is the fastest kayak out there and glides easily thru the water with just one peddler, with two peddlers pedaling lightly it is faster than your trolling motor, plus they can pedal all day long with great ease as long as you carry extra fuel (a couple twinky's and some water lol).
Hope this helps
EDIT:
I posted the reply before actually clicking the link, I thought you were pointing to the Island hopper mirage slot mounted motor option, which is way more expensive and as I describe above, is not well thought out (where would you put it when not using it...). Actually the salt water 30# version you pointed to for $199 looks to me like a pretty good deal to me (if you go in salt water).
In another area of their web site ( http://www.islandhopperoutboards.com/ka ... hobie.html) they sell complete kits specifically for the TI if you don't want to make your own motor mount (the motor mount is the key to everything).
Here is a link to a video from Tom Kirkman using an 18 lb thrust motor that is worth watching
[youtube2]https://www.youtube.com/watch?v=viE66Knbt4o[/youtube2]
Actually the transom mounted version with remote control looks interesting also, if you mounted the motor slightly to one side it would easily clear the existing rudder (http://www.islandhopperoutboards.com/ka ... dders.html), kind of like the Torqeedo 403 setup.
Interesting stuff.
I had an Island hopper gas motor (same company) on my TI for 3 1/2 yrs before switching to a Honda, they are a good outfit, and have pretty good stuff in my opinion.
PostPosted: Tue Sep 30, 2014 2:23 pm
Due to the pitch on the props you're apt to find that the larger motors won't push the TI any faster than the smaller thrust motors. They just burn up battery juice more quickly.
PostPosted: Tue Sep 30, 2014 6:23 pm
Over the years I have purchased the Islandhopper 54# thrust and the 18# thrust watersnake for my AI -which weighs more because I use TI amas with it. I got about 4mph with the 54# thrust and 3mph with the 18# thrust. My islandhopper had a mirage mount and I regretted that. The 18# lasts about twice as long, weights half as much and will take me further on a battery. Neither has the power to move you well in the face of strong currents or a storm. They just assist you wend the winds don't. Islandhopper lasted 2 year before the elements were too much for it (salwater use).
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Sat Oct 30, 2021 4:14 pm
WaterSnake has had a new generation of brushless, 70-lb thrust trolling motor called the "Advance" that operates on a single 12-v deep-cycle, marine battery. It pushes along my Sea Eagle 16-ft FishSkiff near hull speed at 2/3rds throttle. Its Emergency Mode is about 25% more power for brief bursts. If I ever own a Tandem Island again, I would rig the same simple motor mount I had once before: A 2 X 6 painted, laid on edge and not centered over the deck by the scupper holes (the side where the motor will be mounted sticks out much further than on the otherside). Held by four u-bolts (two on each side) I attached 2 varnished, oak dowels. These dowels fit down into the scupper holes even with the bottom of the hull. I han a flat strap from one side of the 2X6 down under the hull and back up to the other end of the 2 x 6. I ratcheted down this strap. Worked great and was easy to remove. But, I suspect the 34-lb thrust WaterSnake would work just as well and go much further on the same battery. And it will weigh much less.
