It is currently Mon Aug 10, 2026 10:00 am
 Post subject: RaiBlaza
PostPosted: Mon Jul 31, 2023 11:17 am
Has anyone found a good way to install a RailBlaza mount outboard on an Aka, with trampolines installed?
I am planning to mount the RailBlaza Camera Boom out there. The only way I've discovered is to put the mount where the Aka bends down into the Ama. I'm concerned that the starport connection my not be strong enough in this position (horizontal. rather than vertical).
Anyone tried this? Or other ideas.
Thanks!
 Post subject: Re: RaiBlaza
PostPosted: Fri Aug 04, 2023 1:31 am
can u explain better? why the railblaza mount on the aka bar should interfere with the trampoline? I think it shoudnt
PostPosted: Sun Aug 06, 2023 6:52 pm
I use the railblaza mounts on my AKA bars with and without the tramps. No issues.
I use four railblaza mounting points all mounted on the Aka bars just prior to the bend down and just outboard of the tramps.
You can see the railblaza mounts on any of my youtube videos: https://www.youtube.com/@seewind
I also use a side pocket railblaza mount in the starboard rear mesh pocket for the gps chart plotter and a flush mount railblaza mount just in front of the rudder.
All have worked fine in rough conditions for over 6 plus years.
Jim
Hobie TI 2022 - Offshore rig - Outboard - having fun!
Hobie TI 2021 - Offshore rig - Outboard - sold
Hobie TI 2016 - Offshore rig - Outboard - sold
Hobie Kona 2014
Hobie AI 2015 - sold
Hobie Rev 13 2014 - sold
Hobie Outback - 2008 - sold
