It is currently Thu Aug 20, 2026 1:58 pm
 Post subject: Capsized my AI!
PostPosted: Wed Jun 08, 2011 7:38 am
I left the Point Pleasant NJ inlet knowing that the winds would reach 25 miles per hour in the afternoon. It was 8 and I had time to reach my exit point just before Sandy Hook. I chose to go over land to avoid going around Sandy Hook since the campground was on the west side quite close to the bottom. I had identified three different exit points leading to the inner waters. The first was the least favorable since it entailed going half a mile over land to reach a finger of water that would lead to the larger waterway. I was the closest and I put the coordinates in my GPS in case things got hairy on the ocean. The second exit was two miles further. That exit required a passage over the sea wall on a staircase: sure to be private. The last exit, my real objective, was another two miles away. I led to a parking lot with an opening on the sea wall. The parking lot was in front of another one that had a ramp on that led to the main waterway.
As I got to the ocean, the swell was quite noticeable. Bluefish jumped all over the place and there were quite a few fishermen. I had a moderate wind on my back. By 10, the swell and the waves were reaching 2 to 4 feet. At 11, the waves were 3 to 4 feet with the occasional set of waves of 4 to 6 feet. Since the current was going against the wind, these waves were quite steep and made my life miserable. I was being propelled forward and I was losing control from time to time. At around 11:30, the wind had reached 20 miles per hour with frequent gusts close to 30. I reefed a bit but it was the waves that were troublesome.
The waves were now breaking over my boat from the back every few minutes. I had to steer looking behind me to avoid capsizing. At 12 it was quite clear that I was now aiming for the first exit. It was only a mile away but not close enough. I made my way close to shore the waves got even steeper. I had stowed everything inside the boat and double wrapped the rest of my gear. I was ready for a trip in the drink. I rolled all of my sail and prepared to demast. I made a sea anchor with my seat. I was seeing people on the beach. I was at the seawall opening and I could see the electric polls indicating the street I was looking for.
I never made it to the breakers. The wave that capsized me never broke. My boat got propelled forward, the tip of the boat dug deep. I jumped in the water to use my body as a counter weight and a sea anchor. I was bear hugging the back of the boat. I flew in the air like a rag doll. Soon the mast went in. I landed on the bottom of the boat. The mast touched the bottom and the two outrigger pins broke at the same time. Even with the tramps, the outriggers were pulled back. One of the tramps plastic snaps broke under the pressure.
It was not difficult at all the put the boat back up. I grabbed the rope with my three dry bags and put them in the boat while a smaller set was now breaking on me. I tugged at the boat and soon touched the ground. I somehow got out of the beach breaks without further spectacle but I swear I had to deploy the strength of a line backer to do it and it was ugly. Had I not been able to pull out before the next large set I think the boat would have sustained a lot of damage. Fortunately for me, since the wind was from the south east, the waves were coming at an angle.
From shore, I studied the waves coming in and the breakers and concluded that the only way I could have made it would have been by rushing in and being very, very lucky. The correct way would have been to use the mast and outrigger all tied together in a big bundle, swim in and tug the whole mess with a rope, perhaps with the help of the people on the beach.
Since the boat was sure to dig in and flip before even getting to the beach break, I could not see any pretty alternatives other than using a huge sea anchor to make it right side up to the breakers. Once there it would have been a very unfortunate moment for the boat since it could not have escaped the beach break fast enough to avoid getting pounded to nothingness.
Once on the beach I got offered a bagel and water. Had I had a hat I could have made a bit of change for the spectacle I had just offered. A bunch of guys spending a few hours on the beach while waiting for a Fish concert helped me take my boat off the beach.
My ordeal was not over. The sun baked me good. I had to haul my gear on the sidewalk for half a mile. I was covered in sweat. I moved one pile of gear, then another, then pulled the boat, over and over again. I got to the “water”. It stank pretty bad since it was right next to a water treatment plant. It looked like a puddle and I had to cross 20 yards of tall and dense vegetation to get to it. I sure could have used a machete. Once I got the hull to the water I noticed that I was standing in deep black goo. Surely this was what was left of human wastes. It stank like a neglected porter potty. I was covered in cuts from the brush. I noticed poison ivy. Hoped I did not get any of its sap on me. By the time I put the boat together and repaired to two outrigger pins I was quite presentable and the boat was covered in black mud and everything was squeaky from all the sand that had made its way in every part of the boat. The rudder would not move without a bit of help from my paddle. I loosened it enough to put it in the water.
I was worried that there would not be enough water to get away from the water treatment plant. I imagined myself stuck in the much a few yards away; looking like quite the fool. Providence got pity and there was enough water for me to make it to the waterway. I stopped at the first docks I encountered and hose myself and the boat.
I saw a Carriage House Marina a little further. I was still aiming for the campground at the base of Sandy Hook but I wanted to ask about the region and consult with local on strategies and timing to cross the bay.
I met Lance, the owner, and he told me that I would not make it against the incoming tide that evening. He said it was no problem if I stayed at his marina and offered a boat to stay in since there were thunderstorms in the forecast; as if the crazy wind was not enough.
He explained that at around 11 the tides would be going out, that I could ride it to the tip of Sandy Hook. I would have to stay away from the very tip to avoid getting taken out to sea. I would then be able to buck the remainder of the ebb current to make it close to the Verazano Bridge in time to the flood. Piece of cake he explained.
I stuffed myself with pizza and went to bed.
BTW, I'm close to Albany! My trip is almost over, sniff.
Rene
http://miami2montreal.com
http://renepotvin.com
 Post subject: Re: Capsized my AI!
PostPosted: Wed Jun 08, 2011 12:26 pm
Good story, Rene! Those are the conditions that will flip an AI, but you did well.
Yes, you are getting near the end, so take care to make it.
Good luck!
PostPosted: Fri Jun 10, 2011 1:38 am
Wow! I mean, really, WOW! You are one tough sailor! Wishing you fair winds and tides the rest of your journey!
It's a good Life, Let's sail!
iHop
Dune TI - 6/4/2011
Camas, WA
