It is currently Tue Sep 08, 2026 1:47 pm
PostPosted: Mon May 31, 2010 8:39 am
I could not longer find the Forum instructions on how to include a photo within
a post message body. The 'post a new topic' pane allows a 'Img' directive to
a photo storage such as Flicker/youtube etc. It appears tho' that a photo can
be directly inserted into the message body. Would someone be kind enough to
restate the instructions?
PostPosted: Mon May 31, 2010 10:39 am
To the best of my knowledge, a photo cannot be inserted directly into the message body.
One way that I've found to post photos is through facebook. I regularly put my photo's up on facebook and wondered if I could use the same pictures here without sharing all of my personal information with you fine people on this forum. :)
Turns out I can.
(I have an Apple computer, but I'm sure things work similarly with a PC)
If I right click my pictures on facebook, I get the option to "Open Image in New Window"
When I choose that option, a new window opens with just the image, and none of the facebook info. From there, I copy the address bar from that window, and post it in between the brackets "{img][/img }" link, and bingo, the picture is posted here, without my personal facebook information.
Don't know if that helps, but I know that a lot of my friends post their pictures on facebook anyways, and this would save someone from posting the pictures to another site just to show them here.
(Of course the problem is that you can do the same thing with anyone else's photo's, so if they set their privacy to "Only Friends" then as a friend of theirs, you can take that photo and show it to the world on a forum like this.) :?
PostPosted: Mon May 31, 2010 3:20 pm
You will have to upload your photo to another photo site then use the img tags.
This is normal fare for a forum - as direct uploads would require server space to host all those photos.
HTH
I'd rather be sailing,
Mark.
PostPosted: Mon May 31, 2010 4:11 pm
See if this helps, Tidalwave:
viewtopic.php?f=11&t=22655&p=100039
The procedure is much the same for all image hosting. Upload your photo, copy and paste the link for forums into your post.
If you can resize your pics to 800 x600 before uploading you will save on data usage.
As recommended by Roadrunner I am using Tiny Pic now which is simpler to use. :)
